CJDEN
Jun 01, 2020Apprentice
Upgrade Readynas Pro 6
I'm a happy owner of a newly aquired elderly ReadyNAS Pro 6 running lates OS 6.10.3 in otherwise stock configuration: Intel(R) Pentium(R) Dual CPU E2160 @1.80GH 1 GB Installed Memory BIOS 08/20/20...
Sandshark
Nov 18, 2020Sensei - Experienced User
That RAM does not say if it is 2Rx8 (low density) or 2Rx4 (high density). But based on the chip count, I think it's low density and will work.
But you will see almost no improvement from 4GB to 8GB unless you are running a number of memory-intensive apps, so the expense is something you should really evaluate.
Igor_d
Nov 18, 2020Tutor
Many thanks at all!
- Igor_dNov 19, 2020Tutor
I have tested two different ram modules.
(4GB) It didn't work:
(2GB) It works:
- SamirDNov 19, 2020Prodigy
Can't see the pictures. I would try those patriot modules since they are known to work.
M395T5160QZ4-CF7 4GB
It didn't work.
PLEXHD PC2-6400-CL6 2GB
It works.I can't say anything about the Patriot.
- StephenBNov 19, 2020Guru - Experienced User
They've been running for some years in my Pro-6.
I did a little googling on this forum, and here are the options posted here (that users reported worked):
- Patriot PGS28G6400ELK
- Patriot PSD24G8002
- Patriot PSD28G800K
- Hynix HMP351U6AFR8C-S6
There likely are more at the old forum site ( www.readynas.com/forum ), but that is only on wayback now, and you can't search it.
- SandsharkNov 19, 2020Sensei - Experienced User
The M395T5160QZ4-CF7 is registered memory, which does not work.
- SamirDNov 20, 2020Prodigy
Thank you for posting these. :) I looked up my notes and apparently there are some particular gskill modules that work as well. I'll see if I can't find the part numbers.
- SandsharkNov 21, 2020Sensei - Experienced User
I have sucessfully used GSkill and OCZ. Frankly, as long as you pay attention to the specs (like avoiding the registered one listed above), I've not found anything that doesn't unless it's just a bad stick.
