CJDEN
Jun 01, 2020Apprentice
Upgrade Readynas Pro 6
I'm a happy owner of a newly aquired elderly ReadyNAS Pro 6 running lates OS 6.10.3 in otherwise stock configuration: Intel(R) Pentium(R) Dual CPU E2160 @1.80GH 1 GB Installed Memory BIOS 08/20/20...
SamirD
Nov 20, 2020Prodigy
Thank you for posting these. :) I looked up my notes and apparently there are some particular gskill modules that work as well. I'll see if I can't find the part numbers.
Sandshark
Nov 21, 2020Sensei - Experienced User
I have sucessfully used GSkill and OCZ. Frankly, as long as you pay attention to the specs (like avoiding the registered one listed above), I've not found anything that doesn't unless it's just a bad stick.
