BernyB
Aug 27, 2016Tutor
Upgrade RN316, then reuse a drive in RN104
Hi, I have 4x3TB drives in a RN316 and 3x3TB in a RN104 for replication, both already runing last os and X-Raid. I want to remove one 3TB drive and add 3x4TB in the RN316 to fill the six bay (3...
- Aug 28, 2016
BernyB wrote:
I want to remove one 3TB drive and add 3x4TB in the RN316 to fill the six bay (3x3TB + 3x4TB), then move the 3TB in the last bay of the RN104. What would be the best way to do it in order to prevent any issue ?
If the RN104 is a full backup, then you could simply do a factory reset on the RN316 with all the drives in place, and recover data from the RN104. That will likely be faster than expanding, though the data won't be available for a bit.
But you can
-Hot-swap one of the 4 TB drives with the 3 TB replacement, and then wait for that to resync.
-Insert the 2nd 4 TB drive. The system will first grow by 3 TB, and then after a reboot will grow by one more TB.
-Insert the last 4 TB - that should sync with no need to reboot.
The system will only sync one new drive at a time, and its best to each that finish before adding the next.
BernyB wrote:
Do I need to unformat the removed 3TB on a PC before to install it in the RN104?
The RN104 should give you the option to format the drive when you insert it.
But if its easy for you to unformat it, then I'd suggest doing that. It ensures the RN104 can't get confused.
Aug 28, 2016Guru - Experienced User
But you can
BernyB
Aug 28, 2016Tutor
StephenB wrote:If the RN104 is a full backup, then you could simply do a factory reset on the RN316 with all the drives in place, and recover data from the RN104. That will likely be faster than expanding, though the data won't be available for a bit.
I prefer expanding over recovering to keep all snapshots in the main NAS.
