JamesCrow
Jan 02, 2013Aspirant
Upgrade Ultra 4
Hi, I have and am very happy with my Ultra 4 but sadly it doesn't enable me to stream 1080p HD movies to my PS3 (via plex) and only manages to stream to my other devices with direct play (as soon a...
chirpa
Jan 02, 2013Luminary
Not possible, the CPU is soldered to the board. The Plus would be the same speed CPU but dual core versus single core, wouldn't be much of a boost for transcoding. You'd be better off with an Ultra 6 Plus with a Core2Duo CPU in it, much more power, and you could swap the CPU if desired. The Pro 6 is a safer bet, as the Ultra 6 Plus may get the 'atom treatment' upgrade revision like the 2 and 4 bays, using the cheaper embedded CPU.
