jhschlak
Jan 27, 2013Aspirant
Upgrading hard drive
Probably a simple question, but I can't find an answer in the FAQ's or on the message board. I have a Readynas Duo with 500GB HD that I removed and replaced with 2TB HD. I can get to front view, but...
Fathead
Jan 29, 2013Aspirant
I have similar situation with jhschlak that I have upgraded both harddisk of my ReadyNAS Duo from 500GB to 2TB. I have no problem with the upgrade except the RAIDiator 4.1.10 was not able to recongize my new harddisk capacity, i.e. it still shows 500GB not 2TB.
Can I do a factory reset on my situation? Will the factory reset delete all my data in my new harddisks?
I'm using Win7 & the firmware of my ReadyNAS Duo is RAIDiator 4.1.10
Thanks
Thanks
