jhschlak
Jan 27, 2013Aspirant
Upgrading hard drive
Probably a simple question, but I can't find an answer in the FAQ's or on the message board. I have a Readynas Duo with 500GB HD that I removed and replaced with 2TB HD. I can get to front view, but...
eton
Jan 29, 2013Luminary
Fathead wrote: ... I have no problem with the upgrade except the RAIDiator 4.1.10 was not able to recongize my new harddisk capacity, i.e. it still shows 500GB not 2TB.
Can I do a factory reset on my situation? Will the factory reset delete all my data in my new harddisks?
Sounds like you've been lucky. Just follow these steps:
viewtopic.php?p=305835#p305835
If you have no problems with the unit, don't factory reset!
