jhschlak
Jan 27, 2013Aspirant
Upgrading hard drive
Probably a simple question, but I can't find an answer in the FAQ's or on the message board. I have a Readynas Duo with 500GB HD that I removed and replaced with 2TB HD. I can get to front view, but...
a_burger_with_f
Jan 29, 2013Aspirant
the volume will not increase unless you only have the one disk in the unit
if you have multiple disks then upgrade both to the 2tb in order to see the volume increase
Agent ID: 82015 NETGEAR ReadyNAS Support Engineer
Contact Information: http://kb.netgear.com/app/answers/detai ... txaw%3D%3D
(US/Canada) 1-888-NETGEAR (Option 4 for Technical Support) / (UK) +44(0)8448 75 4000
