jhschlak's avatar
jhschlak
Upgrading hard drive
Probably a simple question, but I can't find an answer in the FAQ's or on the message board.
I have a Readynas Duo with 500GB HD that I removed and replaced with 2TB HD. I can get to front view, but it says no shares currently accessible. I did not perform a factory reset after installing the 2TB drive. Is a reset all I need to do?
Thanks,
Jeff
  • Hi StephenB,
    Yes, I'm using compatibility mode in IE10. Is there any problem with IE10?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    IE10 broke compatibility with Frontview. If compatibility mode isn't working try a different web browser.
  • I can see the info in RAIDiator when using other browser. Thanks for the support from mdgm & StephenB.
    Cheers
ProSupport for Business
