fussballninja
Nov 20, 2014Aspirant
USB 2.0 faster than USB 3.0
Good day everyone I own the ReadyNAS 102 with 2x 1TB WD Green harddrives. I want to move some movies (60GB) from the NAS to my external harddrive (2,5" Toshiba Stor.E 1 TB). When I use the USB 2.0 ...
Nov 21, 2014Guru - Experienced User
No, that's just the way file shares work. You are copying the files to another drive, and if you do it from a remote PC the data moves through the network.
fussballninja wrote: I did not know that it moves the data through the network if I use the Windows Explorer :S Between the PC and the NAS is only a Switch... is that maybe the limitating factor? It's an Asus GX-D1051...
