j2sw
Aug 24, 2018Aspirant
USB reload on RND2000v1
I have been trying to do a USB recovery on my Readynas. The instructions say to insert the USB stick and then hold the power in for 20 seconds and wait for the lights to blink. My unit comes on an...
bedlam1
Aug 24, 2018Prodigy
Perhaps review Page2 23-24 of the Hardware Manual HERE
EDIT - should have been pages 15-16 for the RND2000.
j2sw
Aug 25, 2018Aspirant
I have the 2000 with no screen on it.
- j2swAug 25, 2018Aspirant
FYI:
This worked for me.
https://kb.netgear.com/22892/How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312
- StephenBAug 26, 2018Guru - Experienced User
bedlam1 should have referred you to pages 15-16 (which I think you should have known if you'd looked at the table of contents).
j2sw wrote:
FYI:
This worked for me.
It's dangerous to use instructions for the wrong platform, especially on a 2-bay model with no LCD screen. If you are lucky, it will just fail. If you aren't so lucky you can lose data.
What firmware are you running on your NAS?
