jamessawle2
Dec 01, 2016Aspirant
VERY Slow and Unreliable transfering files between Mac and NAS box
I have 4 ReadyNAS 104's, all of them are showing the same problems, I can access them fine from Windows based systems over the 1Gb backbone that we have installed here, so in theory no bottle necks! ...
- Dec 04, 2016
More or less resolved. Using a back up to move data around seems reliable and fast. So I have my data set up now where it needs to be on both RNs and a second back up to a USB SSD drive. What I origianlly had trouble with was dragging and dropping from the ReadyCLOUD application or directly from my iMac using Finder. It seems I have a bit to learn about this. I'll post back in a new thread if I continue to have issues.
Dec 01, 2016Guru - Experienced User
jamessawle2 wrote:
Firmware 6.4.2 (reported by RAIDar), 6.2.5 (reported within the admin panel)
That's weird.
Perhaps try upgrading one to 6.6.x and then do a factory reset/restore the data.
I did a factory reset on my RN102 last May (first time since launch) and saw a big performance boost.
Also, make sure antivirus and IPv6 are both turned off.
jtucker
I have just put a RN312 on my Mac based network. It is going to replace an older NV Dou. I have the same trouble. I am trying to copy my files from teh old NAS to the new. Very slow transfer and always crashes after a few minutes. Any idea would be helpful.
