jamessawle2
Dec 01, 2016Aspirant
VERY Slow and Unreliable transfering files between Mac and NAS box
I have 4 ReadyNAS 104's, all of them are showing the same problems, I can access them fine from Windows based systems over the 1Gb backbone that we have installed here, so in theory no bottle necks! ...
- Dec 04, 2016
More or less resolved. Using a back up to move data around seems reliable and fast. So I have my data set up now where it needs to be on both RNs and a second back up to a USB SSD drive. What I origianlly had trouble with was dragging and dropping from the ReadyCLOUD application or directly from my iMac using Finder. It seems I have a bit to learn about this. I'll post back in a new thread if I continue to have issues.
FramerV
Dec 03, 2016NETGEAR Employee Retired
Hi jtucker,
Just wanted to confirm if the issue has been resolved.
jtucker
Dec 04, 2016Aspirant
- FramerVDec 04, 2016NETGEAR Employee Retired
Hi jtucker,
Thank you for the feedback.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards, - jtuckerDec 05, 2016Aspirant
I don't see how to "accept as solution"...
