drivethebus
Aug 09, 2018Aspirant
volume amount on 628x
Hi,
Im confused as to why my storage ammount doesn't seem match my drives.
using xraid and have 7 drives installed: (6)- 10tb ironwolf pro, (1) - 12 tb ironwolf pro.
system is showing tht my to...
- Retired_MemberAug 09, 2018
Hi drivethebus,
6x10 and 1x12 TB gives in xraid (which is raid6 in your case) 45.4 TB, which exactly is what you observe.
You might want to use the Netgear RAID Calculator to verify.
Please go here http://rdconfigurator.netgear.com/raid/index.html
Retired_Member
Aug 09, 2018Hi drivethebus,
drivethebus
thanks for the answer. Just what I was looking for.
