Equinox1
Jun 23, 2019Guide
'Volume Degraded" error - and nothing happens
Hi everybody, Out of the blue, the data volume (5x2TB RAID 6) started showing as degraded, without any other errors or attempts to recover. I've restarted the system, and I got a 'resyncing...
schumaku
Jun 23, 2019Guru - Experienced User
None of the five HDD disappeared on the System -> Volumes view or on the System -> Volumes -> Settings -> Disks ?
- Equinox1Jun 23, 2019Guide
Nope... All green.
Breaking news: again out of the blue, disk #5 showed up as 'Volume data-0' with the message "Remove the volume to use the disk".
I ejected disk #5, inserted it 10 seconds later, and it now started to sync again normally.
I'll keep you posted on the next episodes of this twilight zone story.
- StephenBJun 23, 2019Guru - Experienced User
After the resync, can you post mdstat.log? Just copy/paste it into a reply.
Also download the log zip file, and look for disk-related errors in system.log and kernel.log.
