Equinox1
Jun 23, 2019Guide
'Volume Degraded" error - and nothing happens
Hi everybody, Out of the blue, the data volume (5x2TB RAID 6) started showing as degraded, without any other errors or attempts to recover. I've restarted the system, and I got a 'resyncing...
Equinox1
Jun 23, 2019Guide
Nope... All green.
Equinox1
Jun 23, 2019Guide
Breaking news: again out of the blue, disk #5 showed up as 'Volume data-0' with the message "Remove the volume to use the disk".
I ejected disk #5, inserted it 10 seconds later, and it now started to sync again normally.
I'll keep you posted on the next episodes of this twilight zone story.
- StephenBJun 23, 2019Guru - Experienced User
After the resync, can you post mdstat.log? Just copy/paste it into a reply.
Also download the log zip file, and look for disk-related errors in system.log and kernel.log.
- SandsharkJun 23, 2019Sensei - Experienced User
My guess is your drive 5 has errors. Even if it successfully completes sync, check the SMART status and see if it's time to replace it. Netgear's alarm points are not always ideal.
- Equinox1Jul 02, 2019Guide
Whe is mdstat.log located?
- StephenBJul 02, 2019Guru - Experienced User
Download the log zip file (From the log page of the admin web ui, or from RAIDar). It's in there.
