Arquebus's avatar
Arquebus
Volume does not expand after adding new disk #26757131
Setup: RN516 with 4x 6TB disks (all Western Digital RED WD60EFRX) in X-RAID, running firmware 6.4.1.   I was reaching 90% disk usage so I decided to add another disk (also a 6 TB WD60EFRX). Afte...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Apr 18, 2016
    Looking at your case support has now triggered a reshape of your array and once that completes the volume will then expand.
    The initial estimate as to how long the reshape will take is usually an overestimate. You are using high capacity disks so it will take quite some time. The new disk needs to be synced sector by sector with the other disks to add it to the RAID.
ProSupport for Business
