murdoc
Jan 12, 2015Aspirant
Volume does not expand
Hi folks, I was hoping someone could help me with an issue I am having. I have a Netgear Readynas 314. I recently set it up and performed a factory reset once installing 2x 3TB Hitachi drives. Shortl...
Jan 12, 2015Guru - Experienced User
XRAID won't expand if you add smaller drives than the ones you have installed. The only options are to create a second volume, or destroy the existing volume, and then create a new one.
