brettgavin
Aug 10, 2012Tutor
Volume Expansion Failed - Pro 6
Hi, We have two 6Bay Pros. Both have 6 disks. One is being expanded to 3TB discs using Xraid-2 DR. When replacing the 6th disk, the volume expansion fails. I have rebooted the box 3-4 times and it ...
mdgm-ntgr
Aug 10, 2012NETGEAR Employee Retired
What was the volume capacity when you last did a factory default? If it was e.g. 2TB you can't expand beyond 10TB as there is an 8TB limit for online expansion over the life of the volume. There is also a 16TB limit on the volume capacity (using X-RAID2 DR you wouldn't hit this limit with currently available disks).
