brettgavin
Aug 10, 2012Tutor
Volume Expansion Failed - Pro 6
Hi, We have two 6Bay Pros. Both have 6 disks. One is being expanded to 3TB discs using Xraid-2 DR. When replacing the 6th disk, the volume expansion fails. I have rebooted the box 3-4 times and it ...
brettgavin
Aug 10, 2012Tutor
Ahah! Thank you. I'll do a factory default.
Can you please clarify for me the 8TB limit? Does it mean that we can't expand more than 8TB more than the first size of the volume, or, does it mean that the smaller size of our initial volume (3.5TB, made of smaller disks) has a limit of 8TB/10TB?
Thanks again :)
Thanks again :)
