brettgavin
Aug 10, 2012Tutor
Volume Expansion Failed - Pro 6
Hi, We have two 6Bay Pros. Both have 6 disks. One is being expanded to 3TB discs using Xraid-2 DR. When replacing the 6th disk, the volume expansion fails. I have rebooted the box 3-4 times and it ...
mdgm-ntgr
Aug 10, 2012NETGEAR Employee Retired
The former of those.
Be sure to make sure your backup is up to date as the factory default will wipe it. If you are running say 4.2.21 a factory default will give you a clean setup on that firmware which depending on when you last factory reset (would show in initrd.log in the logs zip file) would have some other nice benefits.
