brettgavin
Aug 10, 2012Tutor
Volume Expansion Failed - Pro 6
Hi, We have two 6Bay Pros. Both have 6 disks. One is being expanded to 3TB discs using Xraid-2 DR. When replacing the 6th disk, the volume expansion fails. I have rebooted the box 3-4 times and it ...
brettgavin
Aug 10, 2012Tutor
Great, thank you for your extensive knowledge and fast responses!
Side question- is it on the Raidiator roadmap to change/expand/remove the 8TB expansion limitation?
