brettgavin
Aug 10, 2012Tutor
Volume Expansion Failed - Pro 6
Hi, We have two 6Bay Pros. Both have 6 disks. One is being expanded to 3TB discs using Xraid-2 DR. When replacing the 6th disk, the volume expansion fails. I have rebooted the box 3-4 times and it ...
mdgm-ntgr
Aug 10, 2012NETGEAR Employee Retired
That'd be up to those who main the Linux utilities used to update them, then for NetGear to test the updates and if satisfied that they are production ready implement them.
