Tarv
Oct 28, 2012Aspirant
Volume Expansion Failed when adding 5th disk - case#19759185
Added a 5th disk to a 4 disk setup. Volume failed to expand but 5th disk is now required for redundancy. Added the disk by powering down and adding, powering on. Since then I've tried: - hot pul...
Marto731
Tarv,
If you don't make headway, I would like you to contact Tech support.
(1) I would have preferred if you had added 5th disk cold, and boot up.
(2) I don't know whether initial Volume was created with, 2,3 or 4 disks.
Possibly, you are hitting on an Expansion limit.
(3) Tech support would need NAS logs, and disk addition history to analyse.
Remote access may be asked for.
Regards Marto
Regards Marto
