Tarv
Oct 28, 2012Aspirant
Volume Expansion Failed when adding 5th disk - case#19759185
Added a 5th disk to a 4 disk setup. Volume failed to expand but 5th disk is now required for redundancy. Added the disk by powering down and adding, powering on. Since then I've tried: - hot pul...
OOM-9
Oct 29, 2012NETGEAR Expert
It looks like it might be related to the same thing the following post was running into:
viewtopic.php?f=66&t=67493#p375264
You can submit the logs with the step provided in my signature. We can confirm this is the issue before following the steps.
