Tarv
Oct 28, 2012Aspirant
Volume Expansion Failed when adding 5th disk - case#19759185
Added a 5th disk to a 4 disk setup. Volume failed to expand but 5th disk is now required for redundancy. Added the disk by powering down and adding, powering on. Since then I've tried: - hot pul...
OOM-9
Oct 29, 2012NETGEAR Expert
I have checked your logs. It seems like you are running into an expansion limitation of the box. You are able to go up to 8TB of expansion per the life of the ReadyNAS.
viewtopic.php?f=51&t=67195&p=373119#p373119
You may need to backup your data, so you can factory default to obtain the full disk capacity.
