Tarv
Oct 28, 2012Aspirant
Volume Expansion Failed when adding 5th disk - case#19759185
Added a 5th disk to a 4 disk setup. Volume failed to expand but 5th disk is now required for redundancy. Added the disk by powering down and adding, powering on. Since then I've tried: - hot pul...
Tarv
Oct 30, 2012Aspirant
That's unfortunate, and I don't know how that's even possible. I'm pretty sure I started at 4 x 3TB disks.
Maybe I started at 3 x 3TB and did one expansion, but I don't think so.
Bought this unit specifically planning to update to 6 x 3TB drives over time... This is going to be an expensive and time consuming upgrade if I need to backup first.
Thanks for the info.
