jst3751
Mar 24, 2014Aspirant
Volume expansion failed
ReadyNAS 4200 v1 Firmware 4.2.25 Configuration: X-RAID2 Existing 12 1 TB WD enterprise hard drives (on the compatibility list) Drives were replaced one at a time, allowing for full rescync to comp...
Mar 24, 2014Guru - Experienced User
My understanding is that if your newly installed disk would expand over 16 TiB that the scripts simply won't expand. And off-line expansion won't work reliably, since the tools on the NAS are not 64-bit safe.
Here's a link to a post describing the process: https://www.readynas.com/forum/viewtopi ... 12#p353102
Note the warning from Beisser and Chirpa not to use that method to expand over the 16 TiB boundary.
That is your current volume size, and how many 2 TB drives did you install before setting the error? Are you running dual-redundancy?
