jst3751
Mar 24, 2014Aspirant
Volume expansion failed
ReadyNAS 4200 v1 Firmware 4.2.25 Configuration: X-RAID2 Existing 12 1 TB WD enterprise hard drives (on the compatibility list) Drives were replaced one at a time, allowing for full rescync to comp...
Mar 24, 2014Guru - Experienced User
Ok. Generally I reboot after each. That might have gotten you farther.
jst3751 wrote: I installed ALL of the drives (one at a time) before attempting to reboot.
Well, no. X-RAID2 added support for mixed disk sizes (for instance 6x1TB+6x2TB) in the same volume to X-RAID.
jst3751 wrote: Yes, the configuraiton is X-RAID2 which is dual-redundancy.
X-RAID2 can be either single or dual redundancy.
