LucDV
Oct 13, 2014Aspirant
volume expansion on ready NAS ultra
I have on my Ready NAS ultra 6 bay with 3 HD's of 2TB (initial install). They were installed in X-raid. Afterwards, I installed 3 extra volumes of 4 TB at different timings, the last one a few days a...
vandermerwe
Oct 14, 2014Master
I'll just repeat what mdgm has already said several times. The 9.2 TiB is the correct capacity after the 2nd 4 tb disk was added.
When you add the 3rd 4tb disk the volume size is theoretically 12.8 TiB which takes you over the 8TiB limit. NO expansion takes place because of this. The Nas can't partially expand to the 11.6 limit.
You will need to factory default.
See http://ram.kossboss.com/xraid/
