galaxgreta
Mar 29, 2025Aspirant
Volume Expansion question
Hi, I have a Readynas 3200 with OS 6.9.5 HF1 and up until some days ago I have 12 2Tb discs using X-RAID2 with a total of 18,15 TB. I now installed 2 new 6TB discs and though that after rebuild wou...
- Mar 29, 2025
I think StephenB got the math wrong and the volume will expand by 8TB (assuming you've got the standard RAID6). Still, since only bays 1-3 can handle a disk >2TB on a 3200, you might want to consider higher capacity drives. But you will need 4, so you'd have to figure out what to do with the the 6TBs you already bought.
Mar 29, 2025Guru - Experienced User
galaxgreta wrote:
Hi,
I now installed 2 new 6TB discs and though that after rebuild would expand the volume but it doesn't!
My questions is:
1. Should it automatically expand the volume with this new added space?
2. If Not...How many 6 TB disc to I need for it to happened?
You are running RAID-6, so the four largest disks need to be the same size.
After you upgrade two more disks to 6 TB, the volume will expand by 4 TB to 24 TB (~21.8 TiB).
