syphonct's avatar
syphonct
Volume Expansion
Running a ReadyNAS 516, currently on firmware v6.10.1 and is showing it as "XRAID", not XRAID2. Has (6) 3TB drives and I'm running low on space. I found a drive on the drive compatibility guide that ...
  • Sandshark's avatar
    Jul 13, 2019
    Yes, it just says XRAID instead of XRAID2.  But it is a newer version than on the legacy models.  For one thing, the expansion limits you have read about do not exist on your NAS.
    I personally tink it is a really bad idea to not have a separate forum area for legacy models, as quite a few things are different with them.
ProSupport for Business
