MattyP1990's avatar
MattyP1990
Volume scan failed to run properly (case number 20717052)
Just added a new drive to my ReadyNAS NV+ v2. RAID sync started fine until the NAS froze up and the only way to boot it back up was by switching it of. Now it's booted back none of my shares are able to be accessed. The device is running in X-RAID2 with two 3TB drives. The logs on the dashboard are as follows.
Tue Mar 5 23:32:24 GMT 2013
System is up.
Tue Mar 5 23:32:23 GMT 2013
The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume.
films
backup
tvshows
Tue Mar 5 23:31:42 GMT 2013
Volume scan failed to run properly.
Tue Mar 5 23:25:14 GMT 2013
System is up.
Tue Mar 5 23:25:13 GMT 2013
films
backup
tvshows
Tue Mar 5 23:24:26 GMT 2013
Tue Mar 5 23:19:20 GMT 2013
System is up.
Tue Mar 5 23:19:19 GMT 2013
films
backup
tvshows
Tue Mar 5 23:18:32 GMT 2013
Tue Mar 5 23:14:24 GMT 2013
System is up.
films
backup
tvshows
Tue Mar 5 23:13:39 GMT 2013
Tue Mar 5 20:49:14 GMT 2013
System is up.
Tue Mar 5 17:27:51 GMT 2013
System is up.
Tue Mar 5 10:59:16 GMT 2013
RAID sync started on volume C.
Tue Mar 5 10:58:45 GMT 2013
System is up.
Tue Mar 5 10:57:50 GMT 2013
Data volume will be rebuilt with disk 2.
Tue Mar 5 10:57:47 GMT 2013
Volume scan found and corrected errors.
Theres a similar thread to this on here with an older ReadyNAS but its over three years old so I cannot post in it.
Thanks, Matt.
  • StephenB's avatar
    Submit an on-line support ticket if you haven't already done so, and then edit the title of your first post to include the case number.
    You might also check lost+found to see if any files are in there.
    Thanks for the reply
    No lost and found file seems to be there anymore. I've contacted tech support and have updated the title, they're going to access the NAS remotely and hopefully all will be sorted.
ProSupport for Business
