MattyP1990
Mar 05, 2013Aspirant
Volume scan failed to run properly (case number 20717052)
Just added a new drive to my ReadyNAS NV+ v2. RAID sync started fine until the NAS froze up and the only way to boot it back up was by switching it of. Now it's booted back none of my shares are able ...
MattyP1990
Mar 06, 2013Aspirant
StephenB wrote: Submit an on-line support ticket if you haven't already done so, and then edit the title of your first post to include the case number.
You might also check lost+found to see if any files are in there.
Thanks for the reply
No lost and found file seems to be there anymore. I've contacted tech support and have updated the title, they're going to access the NAS remotely and hopefully all will be sorted.
