RupertGiles
Jul 01, 2018Apprentice
Volume Scrub duration
RN314 with 4x1TB drives, RAID 5
OS 6.9.3
Approx. 1TB free space
I have my unit configured to perform a volume Scrub twice each year: on January 1st, and July 1st.
The Scrub on January 1st to...
- Jul 03, 2018
Hi RupertGiles
Checking on your disks all your drives are fine. You may want to try disabling Quota on volume and see if there's any change in scrub time or performance.Regards
Marc_V
Jul 02, 2018NETGEAR Employee Retired
Hi RupertGiles
For RN300 series I do think 5 hours or less should be normal run time for scrubbing 4x1TB. Do you have any performance issues when running scrub?
Another thing is to check on the logs for any issues on your disks. You can download the logs and look at smart_history or volume log.
You may want to check this thread as well for other users discussing about the lenght of Scrub maintenance.
https://community.netgear.com/t5/Community-Add-ons/Length-of-Scrub-Maintenance/m-p/1564505#M6159
Hope this helps!
Regards
RupertGiles
Jul 02, 2018Apprentice
Hello Marc_V,
As far as I can tell from looking at the logs, there are no issues with the disks. The scrub did complete successfully, although it took nearly 12 hours.
Here's the log entry from the "Volumes" section:
data scrub 2018-07-01 14:26:33 2018-07-02 02:17:14 pass
The only performance issues I experienced during the scrub was that Time Machine wasn't able to run. This wasn't a major issue because I have other redundant backups: Arq, and Carbon Copy Cloner.
- Marc_VJul 02, 2018NETGEAR Employee Retired
Hi RupertGiles
It would be best if you try and see if this will do the same on your next Scrub using the progress bar StephenB mentioned. You can send in the logs if you want so we can try to check.
Guide to sending logs is in my Sig.
Regards
- RupertGilesJul 02, 2018Apprentice
Logs sent.
- StephenBJul 02, 2018Guru - Experienced User
You might look at the SMART statistics for your drives, just to make sure they are healthy. There are a few places where they are stored, one is disk_info.log (in the log zip).
