Madcow68
Jun 27, 2016Tutor
Volumes and Backup
I have the ReadyNAS 204 with OS 6.5.1 I have been seeing people post about Volumes, I did not do anything with Volumes when I set it up. Should I assume I have 1 Volume? I am new to all of th...
Madcow68
Jun 27, 2016Tutor
Ian-
Perfect. So I should add another 3TB drive and get a USB backup.
If I have 4 drives how many can fail before I lose everything?
What are you using for a backup?
ilneill
Jun 27, 2016Apprentice
Hi,
You can add another 3TB drive... I do not know if you should. If you need the extra space, then it is the easy thing to do.
You should must get a backup if you care at all, even just remotely, for your data. With RAID5 and 4 drives, you can recover from 1 failed drive. Any more than that and you loose the lot. I know that sounds harsh (and I am not even considering sophisticated and expensive revovery services), but RAID is just hardware redundancy. Contrast with a single drive solution and if that drive fails.
My backup solution consists of 2 separate USB hard drives hanging off the back up the RN204. I have scheduled RSYNC backup jobs to copy my data to the USB drives. Yes, I have 2 USB drives - I backup my data twice. I also have myRN204 on a UPS so that power spikes, brown-outs and black-outs do not threaten my data.
Now, you may think that I have gone a "bit far", but I have built this solution over time - I just did not go out and but the lot in one go. I am also in the "prevention is better than cure" fan club, as I know restoring any data from a backup up is far easier than trying to recover it from a failed drive.
I hope this helps,
Ian
