BJB
Jul 05, 2013Aspirant
WDTV Streaming Read Access rights vs. Admin Write Backup
Greetings, I am trying to determine the best approach to setup my user (and groups if necessary) and permissions on my Readynas102 on OS6 and a WDTV Live Streamming device. I will be using the NAS...
BJB
Jul 06, 2013Aspirant
Got it! If I restrict write access to the WDTV via option b) or c), will it still be able to write any metada it finds say for a movie search? I assume it tries to store that on the NAS where it got the movie file from. Just thought about that....
Per the above....I restricted my "everyone" access on a share and then tried to access it from the PC. As expected a login popped up. I used the same username and password I use to login to the NAS (the "admin" login) and it would not give me access. I also tried to set it up in windows credentials and the same popup would not give me access. There is one popup that asks for the network password for the NAS...I provide the "admin" username and my password, then another popup asks for the "network password" to connect to the NAS. This is the typical windows username pref-filled in and a password box. My password won't get me past this to connect.
Since you said my admin account would not get me to the files via explorer, do I take this to mean I should just setup my own new user say called "admin" and give it access to everything and then windows and windows explorer could connect to this new "user"?
Thanks...sorrry for the additional questions. I understood exactly what you said, it is just not responding as expected.
BJB
BJB
BJB wrote:
...Is the same login I use to get to my os6 login and management screen via a web browser also the admin login that would allow me to get to any folder I want with windows (file) explorer with read/write access?Yes.
BJB
BJB
