XrayDoc88
Jan 05, 2019Apprentice
Weird "Unknown" and "Public" Network Issue With Windows 10, ReadyNAS and Static IPs
I have a home network with all computers running Windows 10, except for my ReadyNAS 628X and my pfSense computer router. When a Windows 10 computer is added to a network, Windows 10 somehow magicall...
Marc_V
Jan 30, 2019NETGEAR Employee Retired
Hi XrayDoc88
Not really sure if the NAS is causing this issue since we don't think the ReadyNAS can control anything on what the Windows OS does within the Network or PCs when it comes to Public or private profiles. If in any case, contacting Support might be a good idea so they can check and investigate if needed.
Regards
- StephenBJan 30, 2019Guru - Experienced User
I agree, though I guess it's possible that installing the ReadyCloud application on the PC might affect the Windows behavior somehow.
XrayDoc88: I am wondering if you are assigning private (not internet routable) static addresses, or if you are assigning public addresses.
You should be assigning addresses from the following ranges which are designated for private networks:
- 10.0.0.0 to 10.255.255.255.
- 172.16.0.0 to 172.31.255.255.
- 192.168.0.0 to 192.168.255.255.
If you are using other addresses, it would be reasonable for Windows to assume you were on a public network.
FWIW, you can reserve addresses in your router (pfsense calls this "static IP mappings). That's a better strategy than assigning static IP addresses to clients - it's more easily managed, and makes it less likely that you'll misconfigure a device (resulting in a duplicate address, etc).
- XrayDoc88Jan 31, 2019ApprenticeI am definitely assigning static IP addresses that are in the private range. I use 192.168. 0. X with a subnet mask of 255.255. 255. 0. All of the static IP addresses are also in a separate range from the DHCP addresses that are also active on the same network.
- StephenBJan 31, 2019Guru - Experienced User
XrayDoc88 wrote:
I am definitely assigning static IP addresses that are in the private range. I use 192.168. 0. X with a subnet mask of 255.255. 255. 0. All of the static IP addresses are also in a separate range from the DHCP addresses that are also active on the same network.Ok.
My systems all allow me to reset the network profile by clicking on "Change Connections properties" in Network Status, and then setting the network type to private (or public). Those changes have always been sticky for me. I'm not using ReadyCloud, so it is not installed on any of my PCs.
I suspect that if you
- uninstalled ReadyCloud from the PC
- confirmed that the problem is still happening
then you would find that disconnecting the ReadyNAS from the network wouldn't affect the PC behavior.
