jlficken
Jun 13, 2018Aspirant
What happens to application settings and home directories if you "DESTROY" the volume they are on?
Basically I need to send the drives back that make up the RAID 1 volume that the Home folders and application directories (for Plex, etc) reside on. What happens if I destroy that volume? Will all ...
- Retired_MemberJun 13, 2018
Destroying volume will remove everything in the disks,you can configure backup in admin console to backup home folder to other volume.
subvolume "apps" will be created automatically to other volume if you destroy the first volume.but you will need to reinstall apps again.
Retired_Member
Jun 13, 2018Destroying volume will remove everything in the disks,you can configure backup in admin console to backup home folder to other volume.
- StephenBJun 14, 2018Guru - Experienced User
I did this a while back (but not recently) - my recollection was that both the home folders and the apps folder were migrated to the remaining volume, with no need to reinstall anything. Though I don't use the home folders, so I likely didn't check very carefully.
I suggest backing everything up, then destroy the volume. After that, check to see what was migrated before you restore everything. Let us know what you find.
Also, document your app settings, and make sure you have the deb files for any third-party apps you have installed.
- jlfickenJun 14, 2018Aspirant
I took the plunge and gave it a try last night.
Basically, the Home directories/shares moved over to the remaining share but I don't use them so I'm not sure if data moved too.
The original reply to this topic was correct in that the 3rd party applications do disappear. Happily I mainly only run Plex so I had a backup of my database, reinstalled it, put the db back in, and I am good to go mainly besides refreshing all of the metadata.
It did take 3 tries with "DESTROY" to get the volume to actually disappear which was weird to me but it did go away.
My new WD Gold 10TB drives arrive tomorrow so I will try this all again. I wish it didn't take 4+ days to sync these drives though :-(
I am a bit obsessive with backups so I moved everything from this volume to my main volume since I had space, I have this NAS back up to a RN102, and I have offline backups that are stored off-site as well so I'm good there. Thanks for the tip though!!
