PatrickH
Feb 26, 2016Aspirant
What is the Differenece between Network Access and File Access when using SMB
The Subject tells it all. I would like a brief explination as to what affect the Network Access and the File Access have inside an SMB system. I do not understand the differenece between the two of t...
siigna
Feb 27, 2016NETGEAR Employee Retired
Network Access is connection based. If your user or host doesn't match up with what's allowed in Network Access you won't have access.
File Access controls the permissions of files within the share.
File permissions are traditional UNIX permissions, effective permissions are ordered by user, group, then others.
- ie. if I have a user with no access rights to a folder and they are in group A and group A has rights to that folder do they then Have rights to that folder?
In this situation the user would have no rights to the folder. Other members of group A would have rights. Regardless of others rights (you didn't mention them), the user would have no rights.
ACLs are also available. They take precedence over traditional permissions.
- StephenBFeb 27, 2016Guru - Experienced User
Meaning that any user rights you specify trump the group rights, not the other way around.
File permissions + network access both need to allow access, otherwise it is denied.
In most cases its easier to set the files to allow full access by anyone, and manage access through network security.
- PatrickHMar 01, 2016Aspirant
So what use is the File Access if the only person with direct access to the files is the admin through the web interface?
Also, How do you remove a user from a access list so that they can default to a group permission?
