hp532
May 28, 2017Aspirant
What protection does XRaid offer for large disk arrays?
I’ve been running my 314 for 3 years now with a mixture of disks Disk 1 – Seagate 2TB (ST32000542AS 24k+ hours) Disk 2 Seagate 3TB (ST3000DM001 18k+ hours, the one that has high failure rates) ...
- May 28, 2017
Retired_Member wrote:
Instead, in your situation I would either go with
1) 4 WD Red 3TB or
2) 3 8TB (WD or HGST preferred)
As has been pointed out, XRAID will let you use 2x8TB+3TB with no issue.
Just to comment on the economics, using current Amazon US pricing:
WD30EFRX: $110.00
WD80EFZX: $265.00
4x3TB costs $330 (since he is reusing the WD30EFRX he already has), that gives him 6 TB more storage than the existing WD30EFRX has by itself. So that is $55 per TB gained.
2x8TB+3TB costs $530, and gives 8 TB more storage than the existing 3 TB drive. That is $66.25 per TB gained.
So it is the case that 4x3TB is more economical in the short run. But later on, you will pay a much higher price to expand it again.
For example,
- adding 5 TB to the 4x3TB system will cost $530 (upgrading two drives to WD80EFZX). That is $106 per TB gained.
- adding 8 TB to the 2x8TB+3TB system costs only $265 (adding a single WD80EFRX) That's only $33 per TB gained.
hp532 wrote:
I’ve been reading up on Raid5 and wonder what protection XRaid (which I understand to be Raid5 + volume expansion) offers when used with large capacity disks? Most places suggest that given disks have an error rate of 1 in 10e14 you’d expect a 11TB array rebuild after a disk failure to fail with around 90% probability (11/12.5).
Those are the "death of RAID" sites I think.
But lots of people here have single-redundancy arrays that are bigger than 12 TB, and they have resynced them successfully (often many times). Every time you do a scrub you are reading all the sectors, and I do that every three months on my 15 TB, 16 TB, and 18 TB RAID-5 volumes with no problems. The math says that just won't work.
So it's clear that you can't just blindly apply the math. The error rate is spec'd at < 10e14, and the "less than" clearly is important. Drives are much more reliable than that spec suggests.
jak0lantash
May 28, 2017Mentor
hp532 wrote:ST32000542AS 45k+ hours
A Barracuda LP with 45k+ hours? Yeah, it's time to replace it.
You can read about X-RAID and its RAID layers here: https://community.netgear.com/t5/Using-your-ReadyNAS/XRAID-turned-RAID5-into-RAID6-when-adding-a-drive/m-p/1120084#M113353
If you have 1x 3TB + 2x 8TB, your volume will be composed of a RAID5 of 3 partitions of 3TB and a RAID1 of 2 partitions of 5TB.
You could have use this tool to calculate the usable capacity, but it doesn't include 8TB HDDs... http://rdconfigurator.netgear.com/raid/index.html
