sjdigital
Nov 09, 2011Aspirant
What router to use with Time Machine
I have given up trying to get my BT Home Hub 3.0 to work with Time Machine and my ReadyNAS Duo so I intend to replace it with another wireless router that will. Obviously the Apple Airport Extreme is...
sphardy1
Nov 09, 2011Apprentice
Give it a few hours - you might get some good alternative suggestions. I can only advise you on what I've experienced or been advised myself
I'd recommend that you also go for a router with Gigabit ports though - neither the WRT54G nor the FVG318 offer that. The Duo is not so fast, but a GigE connection should more than double your current wireline performance. (BT Hub does have 10/100 ports right?)
Also a good wireless N router can actually outperform a 10/100 connection, so to buy/use any Wireless N router without gigabit ports is unnecessarily limiting
