sjdigital
Nov 09, 2011Aspirant
What router to use with Time Machine
I have given up trying to get my BT Home Hub 3.0 to work with Time Machine and my ReadyNAS Duo so I intend to replace it with another wireless router that will. Obviously the Apple Airport Extreme is...
sjdigital
Thanks again. Strangely the BT Home Hub 3.0 has just one Gigabit port. I've never understood the logic of having just one such port as surely if a device is connected to that port, then any other device trying to connect to it is constrained by having only 10/100 ports available? Although presumably a Gigabit switch connected to the Gigabit port would work and I need more than four ports as I have two printers, the ReadyNAS and a Powerline device to connect as well as needing to have a port free for connecting a computer when necessary.
But as you say, perhaps there will be other suggestions.
