chirpa
Mar 25, 2013Luminary
whats wrong with this picture.. (chirpa pokes at readynasos)
Running ReadyNASOS 6 with uptime of three hours, receiving a 20kb/s rsync stream (over slow DSL line). Besides that it is completely idle, no web admin open either. # w 00:47:34 up 3:06, 1 use...
chirpa
To remove the default bundled apps, and the unused phoning home apps (unless you want the cloud services)...
# apt-get remove plexmediaserver-ros6 leafp2p vault readydrop rdbroker remote replicate rnp2-installer
The following packages will be REMOVED:
leafp2p plexmediaserver-ros6 rdbroker readydrop remote replicate rnp2-installer vault
0 upgraded, 0 newly installed, 8 to remove and 0 not upgraded.
After this operation, 6,538 kB disk space will be freed.
Do you want to continue [Y/n]?
(Reading database ... 11928 files and directories currently installed.)
Removing remote ...
Removing leafp2p ...
Removing plexmediaserver-ros6 ...
Removing rdbroker ...
Removing readydrop ...
Removing replicate ...
Removing rnp2-installer ...
Removing vault ...
- Mar 10, 2018Retired_Member
