chirpa
Mar 25, 2013Luminary
whats wrong with this picture.. (chirpa pokes at readynasos)
Running ReadyNASOS 6 with uptime of three hours, receiving a 20kb/s rsync stream (over slow DSL line). Besides that it is completely idle, no web admin open either. # w 00:47:34 up 3:06, 1 use...
chirpa
Removing the only 'app' installed, dpkg will try to remove the /apps/ directory, watch out!
To keep from seeing an 'app' for htop, I used Debian's repo instead, for a stock console version (# apt-get install -t wheezy htop)
# apt-get remove htop
The following packages will be REMOVED:
htop
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 160 kB disk space will be freed.
Do you want to continue [Y/n]?
(Reading database ... 11796 files and directories currently installed.)
Removing htop ...
dpkg: warning: while removing htop, unable to remove directory '/apps': Device or resource busy - directory may be a mount point?
