bucky1
Feb 01, 2013Aspirant
When I delete a share it deletes my data as well
READYNAS NV+ v2 with 4 3TB WD Red RAIDiator 5.3 RAIDar 4.3.4 Setup as Flex Raid JBOD with 4 volumes c,d,e,f Accessing console (dashboard) with firefox 18 I been copying all my data onto these v...
Feb 01, 2013Guru - Experienced User
bucky - did you somehow create Backup and Media folders on more than one volume???
As Etz replied, you are not un-sharing a folder when you remove the share. You are deleting the folder.
- Mar 31, 2022Retired_Member
