bucky1
Feb 01, 2013Aspirant
When I delete a share it deletes my data as well
READYNAS NV+ v2 with 4 3TB WD Red RAIDiator 5.3 RAIDar 4.3.4 Setup as Flex Raid JBOD with 4 volumes c,d,e,f Accessing console (dashboard) with firefox 18 I been copying all my data onto these v...
a_burger_with_f
you should be able to delete these shares if they are coming back and on top of that showing up on a diff volume theres something going wrong when you delete it
if its deleting all your data on the device i would just reload the firmware, factory default and see if you are still getting that same issue, if you still have data on other
shares then call tech support
- Mar 31, 2022Retired_Member
