bucky1
Feb 01, 2013Aspirant
When I delete a share it deletes my data as well
READYNAS NV+ v2 with 4 3TB WD Red RAIDiator 5.3 RAIDar 4.3.4 Setup as Flex Raid JBOD with 4 volumes c,d,e,f Accessing console (dashboard) with firefox 18 I been copying all my data onto these v...
Feb 03, 2013Guru - Experienced User
My comments were for the case where you are hosting a share from Windows. I agree you can't delete (or unshare) a network folder hosted on another machine, though of course you can delete the files in the share if you have the right permissions.
Etz wrote:
StephenB wrote: In Windows, you can unshare as well as delete. I think bucky was thinking that removing the share from dashboard was the same as windows unshare - when of course it is really the same as delete.
Maybe, havent used windows for a while...and actually I never shared anything out on a Windows machine...
If you use Windows as pure client, I really doubt that you could actually delete share on a server without actually accessing it from GUI or CLI... :roll:
- Mar 31, 2022Retired_Member
