bucky1
Feb 01, 2013Aspirant
When I delete a share it deletes my data as well
READYNAS NV+ v2 with 4 3TB WD Red RAIDiator 5.3 RAIDar 4.3.4 Setup as Flex Raid JBOD with 4 volumes c,d,e,f Accessing console (dashboard) with firefox 18 I been copying all my data onto these v...
Etz
Feb 06, 2013Aspirant
On ReadyNAS there is no "unshare" option via Dashboard, there is only option to create share or delete it.
If you want to unshare it, you can remove CIFS, NFS, AFP, FTP or HTTP access to that share.
Basics which work under the hood, are basically same in all OS`es which use Samba.
It is also covered in documentation: http://www.downloads.netgear.com/files/ ... 5Sep12.pdf
- Mar 31, 2022Retired_Member
