bucky1
Feb 01, 2013Aspirant
When I delete a share it deletes my data as well
READYNAS NV+ v2 with 4 3TB WD Red RAIDiator 5.3 RAIDar 4.3.4 Setup as Flex Raid JBOD with 4 volumes c,d,e,f Accessing console (dashboard) with firefox 18 I been copying all my data onto these v...
bucky1
Feb 06, 2013Aspirant
Etz wrote: On ReadyNAS there is no "unshare" option via Dashboard, there is only option to create share or delete it.
If you want to unshare it, you can remove CIFS, NFS or HTTP access to that share.
Basics which work under the hood, are basically same in all OS`es which use Samba.
For god sakes, look into manual if you dont what youre doing: http://www.downloads.netgear.com/files/ ... 5Sep12.pdf
Hi Etz....ok thankyou I understand, I have read the manual..I see the distinction between unshare and delete a share.
See my question which I just wrote above your post
- Mar 31, 2022Retired_Member
