fwdnetad
Jun 08, 2016Aspirant
Will setting my NAS back to default settings erase the second attached volume as well?
I have a ReadyNAS expansion chasis attached to my ReadyNas516. If I disconnect the chasis, then set the ReadyNAS516 back to default settings, then reattach the expansion chasis; will the data on the...
BrianL2
Jun 09, 2016NETGEAR Employee Retired
Hi fwdnetad,
Kindly read the EDA500 FAQ from this page.
I hope this answers your question.
Kind regards,
BrianL
NETGEAR Community Team
- StephenBJun 09, 2016Guru - Experienced User
BrianL2 wrote:
Hi fwdnetad,
I don't think it does actually - he wants to remount the EDA volume after the reset, which isn't one of the use cases in the faq.
It would be useful to be able to do this - it'd also be useful to be able to dismount/remount volumes within the NAS when you are using flexraid.
